ls1 axle w/ lt1 brakes.
Car: 84 S-10:(
Will lt1 brakes fit on an ls1 10-bolt? Do you have to shim the backing plates? I'm trying to get my 10-bolt ready to drop in, but I can't seem to find any ls1 brake parts.
Will I need an adjustable prop valve? I'm going from disc to disc.
Thanks,
FBird
Thanks,
FBird
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
They should bolt in fine with the LT1 backing plates and you shouldn't have to shim anything. If so, Andy Z28 has some shims available IIRC. I wouldn't bother with the prop valve either.
Ed
Ed
I have an 02 TA rear with a brake setup from a 94 Z28 and can tell you they DO NOT fit. The rotors will hit the caliper bracket. You can solve this 1 of 2 ways. Install thin spacers between the rotor and axle hub, or grind down the inner edge (facing the back of the rotor) of the bracket to clear. You will need to grind off a good bit, but not so much that it would affect the brackets strength.
LS1 rear brakes sit out farther than LT1 rear brakes, and that's due to the LS1's emergency brake setup. That's what causes the interference.
Others on this board had the same problem, I believe Mr_Dude_1 was one of them.
I stand corrected, thanks Marc. There must be a difference in axle lengths then.... I would think the axle flanges would be the same with just the minor differences in the brake setups.
Ed
Ed
Ed
Ed
New info to me, I haven't done much work with the 2 types of rears (LT1/LS1).
Ed
Ed
1 Post
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
It is true. LS1 or all 4th gen axel's for that matter are longer than 3rd gens.
All 4th gens are interchangable. There are some differences tho. 3 and 4 channel ABS. 4 channel has a reluctor gear on the hub. 3 channel rides off the ring gear.
LSD's/bearings/gears/LCA's, pan hard bar ect are interchangable from 3rd to 4th gens. Keep in mind the earlier 3rd gens have 26 spline axels. All 4th gens have 28 spline axel's. I forget what year the 3rd gens switched to 28 spline axels. Think it's 89 or 90. That will make a difference if you are changing carriers and the like.
Right..I was talking about the individual axle length, not the overall rearend length. 4th gen rears are about 2" longer per side.
GM swapped to 28 spline axles in late '89.
Preachin to the choir but thanks for the input.
Ed
Ed
1 Post
Engine: SBC, LS-x
Ed
Ed
Well jumped up jeezus on a stick,
MY name is Ed too!!!!
I supppse now someone should say....
All Ed's think alike!
1 Post
Car: An Ol Buick
Engine: Vsick
<Confused>
Will a LS1 rear disc set-up bolt onto a 3rd Gen, other then emergency brake cable issues?.
Are all the axle lenght differences because the axle housings are different?. Or because the backing plates, are different?.
TIA
TIA
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
btw, we did this swap since it was taking so long to grind down the LS1 brakes to fit over the 15" Pro Stars.
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
I'm interested to hear some more information about the LT1/LS1 difference in axles. That's unlike everything else I've been told. I could see the axle tubes being shorter a bit to make up for it, but I thought the axleshafts were the same length among all 4th gens.
Originally posted by Zepher
I put a set of 96 LT1 brakes on a 98 LS1 rear and they sat fine and worked ok I guess. did they change something on the later year LS1 rears?
Odd. I have a 3 channel rear on mine, maybe you have the 4 channel? Others on CamaroZ28.com, all 4th gen guys, have had similar issues.
sailtexas186548
01-19-2016 12:21 PM
codeysabatini
11-10-2015 04:07 PM
