Brake Hose Replacement
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
Anyone: Replace a disc brake hose (RF) and no bleed flow? Any ideas before I remove? Thanks
Engine: 4++,350 & 305 CIs
U are going to replace BOTH hoses aren't you???
if u bleed them right it should squirt out the bleeder... with the pedel pushed down and the bleeder open..
close bleeder and pump the brakes then hold and open the bleeder repete untill no air comes out...
Car: '91 Camaro
Transmission: Auto.
Right you are Tony, Thanks. Just RS jacked now and by the book. Replaced strut and spied frayed hose, replaced, never had this to happen, oh well.
Car: '91 Camaro
Transmission: Auto.
Update, Contaminate, thick, mud like 13 yr old(guess) brake fluid(I think) does not flow well. It was unbelieveable, think your fluid looks ok thru that discolored reservoir? It will fool you and I so, pop the top and if its not clear to the bottom with a finger slide, you are contaminated and unsafe IMHO as information. Good Luck
1992 Trans Am
05-10-2023 07:19 PM
