LS1 brakes: Anyone know fastener torque specs?
Car: 85 IROC
Engine: 355
Transmission: Tremec 5 speed
I have not installed the bolts in my LS1 setup with a torque wrench yet.
Does anyone know the recommended torque specs for the caliper carrier to adapter bracket bolts and the caliper to caliper pin bolts?
Oh yeah, how about the adapter to spindle bolts. I have them in now at 90ft/lbs which is what I saw on a page discussing a 1LE swap.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Hi Chuck. I would use those on Dan Burke's webpage as a guide. Since we are using appromixately the same mounting spots as the 1LE mounts, I'd go with those.
I should have mine on next week.
Ed
Ed
Car: 85 IROC
Engine: 355
That was my intent but 137ft/lbs for the caliper carrier to adapter bracket seems like a lot of torque. I may try asking around on a 4th gen board to see if one of those guys can tell me some numbers. If I do that I'll let you know what they say.
Car: 1982 camaro (13.063 @ 105.61mph)
Engine: 5.7
Transmission: T5 with a 3.27 9 bolt
Document ID# 773150
2002 Chevrolet Camaro
Fastener Tightening Specifications
Application
Specification
Metric
English
Brake Caliper Bleeder Valve
12 N·m
106 lb in
Brake Caliper Guide Pin Bolt
31 N·m
23 lb ft
Brake Caliper Mounting Bracket Bolt
100 N·m
74 lb ft
Brake Hose Fitting Bolt
55 N·m
41 lb ft
Wheel Nut
140 N·m
100 lb ft
Document ID# 773150
these are the torque from the 2002 camaro service manual for the front brake
hope this help
edit:
while we're at it, the rest of specs for these brake
Disc Brake Component Specifications
Application
Specification
Metric
English
Front Brakes
Rotor Discard Thickness*
30.7 mm
1.209 in
Rotor Maximum Allowable Lateral Runout
0.06 mm
0.002 in
Rotor Maximum Allowable Scoring
1.50 mm
0.059 in
Rotor Maximum Allowable Thickness Variation
0.025 mm
0.001 in
Rotor Minimum Allowable Thickness After Refinishing
31.08 mm
1.223 in
Rotor Thickness, New
32.0 mm
1.26 in
Rear Brakes
24.51 mm
0.965 in
0.06 mm
0.002 in
1.50 mm
0.059 in
0.025 mm
0.001 in
24.89 mm
0.980 in
25.90 mm
1.020 in
* All brake rotors have a discard dimension cast into them. Replace any rotor that does not meet this specification. After refinishing the rotor, replace any rotor that does not meet the minimum thickness after refinish specifications.
Document ID# 706333
Application
Specification
Metric
English
12 N·m
106 lb in
31 N·m
23 lb ft
100 N·m
74 lb ft
55 N·m
41 lb ft
Wheel Nut
140 N·m
100 lb ft
Document ID# 773150
hope this help
edit:
Application
Specification
Metric
English
Front Brakes
30.7 mm
1.209 in
0.06 mm
0.002 in
1.50 mm
0.059 in
0.025 mm
0.001 in
31.08 mm
1.223 in
32.0 mm
1.26 in
Rear Brakes
24.51 mm
0.965 in
0.06 mm
0.002 in
1.50 mm
0.059 in
0.025 mm
0.001 in
24.89 mm
0.980 in
25.90 mm
1.020 in
Document ID# 706333
Engine: 5.7
no prob, if you want any other specs concerning LS1 car (camaro/firebird/corvette) or any other GM car/truck newer then 98 for that mather just ask me
Car: 85 IROC
Engine: 355
Dr BBS,
I second Ed's comment. Very good information. I'm glad I asked about the torques specs. 74lb/ft sounds a lot more reasonable for the caliper carrier than the 137 lb/ft 1LE spec.
Bohemian
08-15-2017 05:11 PM
86White_T/A305
09-21-2015 05:28 PM
