Proportioning valve mod/Better rear brakes update
#101
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: update
this thread is awesome! i dont care who's right ive got an 87 disc/drum brake car that i swapped the rear to a '02 SS rear with the discs... im thinking of getting rid of the valve alltogether just replacing it with a piece of pipe... if it dont stop, i got tripple A
front can be straight pressure, but the rear HAS to be biased
#102
Car: 1987 Firebird, Dad bought it new
Engine: 5.7L Vortec w/ LT4 Hot cam
Transmission: 700r4 transgo shiftkit 2600 stall
Axle/Gears: 3.42 '02 SS 6 spd rear
Re: Proportioning valve mod/Better rear brakes update
no just the rear, im disconnecting my front brakes
#104
i do all my own stunts
#105
Car: 1991 Pontiac Firebird
Engine: 355 TBI
Transmission: 7004R
Axle/Gears: 3.27/42 ?
Went ahead and tried something different. I got a 1 3/4 spring and installed it. So now I got a problem My rears lock before the fronts do.
My car is a 91... with the 1LE rear disk swap.
I tried turning while I had the rears locked and well pretty much your screwed if there's something you need to maneuver around.
Come to think about it, my fronts never really locked before....
#106
the knowledge i have gathered from this thread has lead me to believe that if your rear brakes lock first that is good and you should slam the brakes, then slam the gas, then slam the brakes and slame the gas while you drive as fast as possible around turns... they call it "trail braking" and... its awesome
#107
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
I originally had rear drums, but I swapped on a LS1 rear end, while replacing the fron with Z51 brakes (basically oversized C5 rotors with C5/LS1 calipers).
So can I modify my old proportioning valve and make it work ? Or do I have to get one from a disc/disc car ?
1992 Trans Am
05-10-2023 07:19 PM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
