drum to O.E. J65/1LE PBR disc swap
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Finally did this swap, just coulden't stand the sight of the huge drums behind the wheels.
It was well documented, many thanks to these guys:
http://www.andyz28.com/3rdGen/1leupdate.html
https://www.thirdgen.org/forums/faq-...iscs-89-a.html
http://www.ws6transam.org/1LEbrake.html
https://www.thirdgen.org/forums/brak...drum-rear.html
https://www.thirdgen.org/ls1reardisc
http://home.comcast.net/~afgun/cars/1LE_retrofit.html
Important factor was to use O.E. parts, otherwise it would not be street legal, or insane amounts of money would need to be spent to have everything tested and approved.
Once the drums and accessories removed, I decided to grind away around 2 mm off the axle flange to be sure the O.E. disc will fit over it.
Traced a line with a marker as reference, to help take off an equal amount all around it.
1 Post
Car: 91 Trans am
Re: drum to O.E. J65/1LE PBR disc swap
A clean axle flange and loctite to glue the axle spacer ring in place.
Got the "Rear Axle Spacers (pair)" from andyZ28 http://www.andyz28.com/catalog.htm
The Latex glow is practical to keep the dirt out of the axle
Pressed in new wheel studs, a little longer then the stock ones, for the case I would need that little bit longer, sometime in the future.
Part# Dorman 610-323 (M12/1.5 x 54 mm)
1 Post
Car: 91 Trans am
Backing plate shimms are used to center the caliper bracket over the disc, requires to install the axle and caliper bracket a couple times.
Wery little grinding is required to the drum axle flange, to clear the shim.
Shim is also used as template to drill the holes for the disc backing plate bolts.
"Shim Kit (2 ea. .032" shim templates & 2 ea. .060" shims)" from andyZ28 http://www.andyz28.com/catalog.htm
Not sure why the bolt on the E-brake bracket needs to be that long.
1 Post
Car: 91 Trans am
I could not find any O.E. disc backing plates, so I ended up with new replacements from Ebmiller http://www.flynbye.com/catalog/i29.html
I left the rear axle flange as is for now, for the case I stumble across an uncool inspector.
The e-brake cable seems too long, at least thats what I thought at first, though after installing, then hanging them up correctly and pulling the e-brake once, they fit perfect.
O.E. part# from Dorman is C94264 (for 89-92 models)
1 Post
Car: 91 Trans am
Instalation of the Rear axle lines for disc brakes is easy and they are available from http://www.finelinesinc.com/catalog/...oducts_id=1153
Luckily, reproductions of the O.E. "Brake Line Brackets (set)" are still available from http://www.andyz28.com/catalog.htm
The mounting holes are already drilled in the drum axle.
Here are two pics of the L and R PBR calipers, these are from early 4th gens but are basically identical to 3th gens PBR calipers.
Notice the different design at the back were the banjo bolt holds the rubber brake line in place, I hat to buy 3 R calipers to get one that would match the L side one :go crazy:
PBR rear caliper hardware were also in all different colors, so I ended up with a matching set from Ebmiller http://www.flynbye.com/catalog/i233.html
1 Post
Car: 91 Trans am
Drove around with the disc drum combination valve for a little while because Bruce from Hawksthirdgenparts, sent me a dirty and clogged 1LE valve, but I recived and installed the clean replacement that I have ben told comes from Ebmiller.
I am courious to test the difference.
Replacing the combination valve/ proportioning valve, requires to empty the whole master cylinder and reservoir.
The 89-92 O.E. rear disc specs:
Outer working diameter 11.65 in
Inner working diameter 8.31 in
Thickness 0.79 in
Matl & type, Cast iron Vented
The disc brakes sure do look much better behind the wheels
I upgraded the front with 1LE brakes already a couple years ago, got the complete kit from Ebmiller http://www.flynbye.com/catalog/i55.html, still working great.
Front 1LE O.E. specs:
Outer working diameter 11.86 in
Inner working diameter 7.77 in
Thickness 1.03 in
Thickness 0.79 in
Thickness 1.03 in
Engine: 4++,350 & 305 CIs
If its what Im thinking of, it holds a steel and rubber dampener. they started putting them on in late 91 or early 92.
edit: just looked at the pix and yup thats what its for.
I'm curious as to why people bother with the shims, which require pulling the axles out a couple of times, when you can just sandwich washers in between the backing plate and carrier to get the same effect and not remove the axles multiple times.
I can only speak for myself, but I used shims because that's the way GM assembled and because shims simply seem tidier in application than washers.
Here's a pic of the dampener, should anyone be interested:
http://www.ls1tech.com/forums/conver...-calipers.html
JamesC
JamesC
1 Post
Car: 91 Trans am
Ok, thanks, I knew about the damper, but none of the 3 91-92 J65 equipped camaro/firebirds, I worked on the brakes, had the dampers.
Probably going to replace that long bolt with a short one someday, if no noise awakens.
I really prefer the shims behind the backing plates, with this swap the axles have to come out. Installing the correct shims, results in 30 minutes more of happy wrenching, well worth a nice job
"There's a slight difference in 3rd and 4th gen calipers and you got a 4th gen caliper. They aren't finned all the way (LS1s mainly), the e-brake bracket is stronger to account for the steel dampener, hence the extra plate, and that big bolt thing is for holding the big steel vibration dampener that the '93-97 LT1 calipers come with. No big deal really as they will work the same, it's just that they look different. The 4th gen parts are becoming easier to find so that's what you got."
That said, IIRC, TTOP350 once mentioned that the dampener was original to his 92.
JamesC
1 Post
Car: 91 Trans am
Did you use a shorter bolt, or just leave as is?
Another thing I was wondering about, are the e-brake cable guides on the differential cover from your wery helpful tread https://www.thirdgen.org/forums/post...606-post5.html
I do not remember seeing them on 3rd gens either, were they part of the O.E. ?
IIRC, those were fourthgen guides.
JamesC
Build date of 09/91 and it has the factory dampeners
1 Post
Car: 91 Trans am
3rd gen https://www.thirdgen.org/forums/atta...s-89-lline.jpg
3rd gen https://www.thirdgen.org/forums/atta...s-89-rline.jpg
The bolt also appears to have a structural function, on the 4th gen bracket.
Thank you alot for the good pic, it shows clear how the dampener is bolted on the rear and higher up vs the 4th gen dampener bolt.
1 Post
Car: 91 Trans am
Little road test report, the difference in braking is wery noticeable between the 1LE prop. valve and the J41/J42 (disc + drum) prop. valve.
Diden't do any crazy braking yet, but overal it feels like it brakes more.
Car: 1991 Z28
@thomas1976. Did you notice if the 1LE rear or front brakes pushed your wheels out any farther? I have drums in the rear too.
1 Post
Car: 91 Trans am
The drum is 4 mm (0.1575 in) thick, were it contacts the axle flange, and comes with a 3 mm extra spacer.
The rear disc is 7 mm thick, were it contacts the axle flange.
*If you add the (drum) spacer to the disc, it sticks out 3 mm (0.1181 in) more.
In this circumstance, the wheel doesen't center it self anymore and requires to evenly hand tighten the Lug nuts for precise alignment, before final torque.
The stock studs also appear a little short for discs with that extra spacer, I used Part# Dorman 610-323 (M12/1.5 x 54 mm), for this and the following reason.
The total of the front (outside wheel to outside wheel) with 1LE brackes, mesures around 14 mm (0.5512 in) larger then the total of the stock rear (outside wheel to outside wheel).
I wanted to be able to even out this difference, by adding a 7 mm spacer on each rear side.
Eric-86sc
04-03-2016 03:52 PM
