CTS-V calipers and 17" wheels
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Searched for a conclusive answer for quite a while and decided to see for myself
14" C6 Z06 rotors are out, atleast for 17" wheels. Must use the C6 Z51 13.4" rotor
Here are pics of a 14" rotor in a 17" corvette wheel using the standard 2" spacer
Its actually touching the weights
To clear it took another .5" of spacing, but even then it didnt even have 1/8" of clearance from the hoop of the wheel. Hard cornering will flex the wheel that much, Ive seen it on our FSAE car. Besides, the combined spacer distance is nearly 3". 2" spacer, .26" rotor, .5" shims. Hard to fit that under the wheel well
18" corvette wheels clear the 14" rotor just fine. The CTS-V caliper is tapered already to clear the Cadillac wheel, so grinding a little wont afford any more clearance on 17's
Re: CTS-V calipers and 17" wheels
Pocket, you're right ... check out this thread:
https://www.thirdgen.org/forums/brak...er-swap-6.html
Dewey did it under 17" wagon wheels. Had to use a 13.4" Z51 rotor. As far as I can tell, he's the only one who's done it. I emailed ebmiller about buying a bracket (I run 10 spoke ss wheels) but I never heard anything back.
Chuck
Chuck
Car: 91 Trans Am
Engine: LSA
Z51 rotors are on order. Just had to see for myself if 14"s were at all possible
Car: 91 Trans Am
Engine: LSA
I didnt notice any pad surface hanging over the rotor. If anything the rotor is still bigger than the pad
The CTS-V/13.5" rotor bracket and printer scale. Notch is to clear a web on the caliper. If that web is ground down, the notch can be omitted
Redesign of the LS1/12" rotor bracket. Also works for the CTS-V caliper on 14" rotors
A friend of mine is doing a hybrid upgrade on his LS1 car too, so I figured someone may use this in the future. LS1 caliper/13.5" rotor
All work best being 3/8" or thinner
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
hey pocket, thanks for the drawings, those will help out a lot.
question.. more of comment question. those CTS-V calipers are upside down/or mounted in the back of caliper, note the bleed valve position, this is due to the CTS-V having the calipers mounted forward of the rotor.
Now as i understand it, the new Camaro 10/11 SS calipers are the exact same caliper, with the exception of the caliper being mounted as your picture, with the bleed valve on top since that how the Camaro's are mounted..
Is this going to be an issue if the bleed valve is upside down?
Car: 91 Trans Am
Engine: LSA
The one in the pic is upside down. I loaned my pass side to a friend to mock-up on his car along with one of my rotors
Bleed valve points up in all cases. Hard to bleed with it pointed down
Camaro calipers have a larger hole, so either use a shoulder bolt or drill/tap the bracket a bit larger. The hose connects to the upper boss on the rear so you can use the stock brake hoses instead of the 1LE hoses like all other brake upgrades require
Engine: 4.3 Turbo
Transmission: 4L60
any modifications for the rotors at all? do you have to use a custom hub?
Car: 91 Trans Am
Engine: LSA
Mod the hub like all brake upgrades, mod the spindles, custom bracket bolt it all together
Stock Z51 rotors, stock CTS-V calipers, stock 1LE lines
Car: 91 Trans Am
Engine: LSA
I dont make any brackets myself. The drawings are posted so you can build your own
13.5" rotors are the C6 Z51 fronts with heavy duty brakes. If you're already using 18" wheels, go ahead and get 14" C6 ZO6 rotors
Car: '91-Z28/'03 Honda 919
Axle/Gears: '99 Zexel 3.42
Is that picture with the 13.4 inch Z51 rotor installed or is that the 14 inch? From everything I have read there is at least a small amount of pad hanging off, I am assuming you have driven this setup by now? Any feedback?
Anybody know if these calipers are still available new?
Just checked with the dealer and they are still available.
Car: 1986 Pontiac Firebird
Engine: 97 LT1 W/ Alot of goodies.
Transmission: 4L60E W/ Yank SS3600
Axle/Gears: 3.27 9 Bolt BW
If you get some bracket mades let me know. I would take one.
Talked to a CNC shop today and they said if I brought them a cad file they could do it and it would probably be about 80 bucks for a pair so the more I have them do the cheaper it would be. Still need to see about getting the questions above answered before I go for it.
rb85TA
26
09-14-2015 10:29 PM
rudolphschenker
09-04-2015 02:41 AM
