C6 Z06 front brakes...
Old 04-04-2009, 10:54 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I don't know what all pads you guys use but Carbotech has a one piece pad setup to ditch the 12/8 individual padlet design. Still uses stock clips and caliper bolts and is offered in every compound they make. I think it's kind of cool.
Thread at Corvette Forum: http://forums.corvetteforum.com/c6-z...compounds.html
Pictures: http://picasaweb.google.com/carbotec...ePiecePad2008#
Old 04-04-2009, 01:30 PM
TGO - 10 Year Member
//<86TA>\\'s Avatar
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
Re: C6 Z06 front brakes...
thats good to know! i've been thinking about ditching the c5's for a c6 setup but i didnt like the lack of pad selection! thanks!
Old 09-19-2009, 02:51 AM
Almo the Pirate's Avatar
Car: 1989 iroc-z
Engine: mildly built TPI 350
Transmission: 97 T56
Axle/Gears: 3.73 posi
ive been thinking about putting those big z06 brakes on my car eventually.
are they any harder to install than the normal c5 brakes?
and how much better are they?
Old 09-19-2009, 12:19 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
https://www.thirdgen.org/forums/brak...brakes-c6.html
https://www.thirdgen.org/forums/brak...r-mouting.html
No harder than any other brake swap. Use a cut down rotor and modified spindle and bolt whatever adapter you want on there and you're golden. People have talked about cutting off steering stops but I didn't have to. YMMV.
As for better...for a street car it's not going to matter much because you're pad choice and tire compound probably aren't going to utilize the potential of the larger diameter rotor/caliper pistons. But it DOES look cool.
Old 09-19-2009, 12:38 PM
Car: 1989 iroc-z
well id be putting 18x9.5 C5 z06 rims on the front and 19x10.5 on back.
plus eventually id be getting another set of rims for race rubber, so those brakes would rock there.
but i wouldnt be doing those brakes specifically for a few years.
ill just put C5s for now.
Amillionoh7
05-24-2020 08:01 AM
1992rs/ss
05-19-2020 07:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
zayne0
08-24-2015 07:22 PM
TMZIrocZ350
Exterior Parts for Sale
08-08-2015 05:55 PM
Quick Reply: C6 Z06 front brakes...
