Big Problem!!!
Big Problem!!!
Hi guys! Ok, got all the Ground Effects. I put on the front Nose, Everything is fine so far. Ok, now, I go to put on the long side peices and Damn! I got a problem. You know the screws the screw in on top of that middle piece, theres nothing to screw them into. i noticed that when I took the peices off at the junkyard, there is a metal peice welded under the car so that the top of the ground effects can be screwed in. but what can i do and what have you guys done about that, i really need to know.
Oh yeah, I am gonna take some pics tommarow and should have them posted of my SC to Z-28 transition process. Later and Thanks!
Car: 87 Grand National
Engine: 3.8 SFI Turbo
Transmission: BRF 200R4
I had the same problem when I did mine. The metal piece your talking about should screw off. I just used metal brackets from lowes for mine. They hold up fine.
gixxer92
09-01-2015 04:32 PM
