Takking off ***#$%^ GFX ... a Little Help Please!!!
Well, I need to take off the ground FX of of my 87 TA. I got everything else off except the part that is attached to the doors. I figured it bolted in under the door panel, but after taking it off I can't find a single screw for it. (One that might be for it, but I can't reach it).
How in hell do you take them off??? Do they just snap on and off or waht?
Any help at all will be greatly appreciated.
thanks,
-Max
thanks,
-Max
Max,
Is it the bottom piece that goes on the bottom of the door ?
If it is, On a pair of 88 Iroc doors I put on my 87 FB, they have 5 little barrel nuts on the bottom inside the door they have access ports in the bottom of the doors and and a 10 mm socket and a long extension, there should be 3 inside the doors,then 2 outside 1 on either end of the door.
I hope that helps, it did the job for me.
Vance
Vance
Pac J
05-17-2020 10:44 AM
BumpaD82
02-26-2016 02:57 PM
383backinblack
10-14-2015 08:50 PM
