How do i remove my hood
Old 03-12-2002 | 04:20 PM
RB's84camaroF-41's Avatar
first off i know its a stupid question but i need to remove it, from what i can tell it looks like really big screws hold it on. so what tool do i remove it with it looks kinda like a phillips head..kinda not
Old 03-12-2002 | 04:23 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
See the bolts that go through the hood-hinge into the hood? Turn those counterclockwise.
Old 03-12-2002 | 04:24 PM
thanks Jim
Old 03-12-2002 | 04:26 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
make sure someone is holding the hood.
Old 03-12-2002 | 04:28 PM
thanks for saving me from a concussion there
Old 03-13-2002 | 12:09 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
If you take it off by your self. Dont let it knock the crap out of your head.Use a 2x4 or something to hold it up.
Old 03-13-2002 | 12:16 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
Also, be careful, as once you unbolt the hood, it tends to want to slide towards your windshield, and ruin your day.
Hood removal is much easier with two people, and much easier to align the hood, too.
Ever try aligning a hood by yourself?
Old 03-13-2002 | 06:19 PM
HrdRockA4305's Avatar
I'd say have you plus 2 others there just to be safe. Thats a big hood.
Old 03-14-2002 | 11:01 PM
Chevy83Z28's Avatar
I agree with HrdRockA4305 .. one guy holding the hood on each side and another using an air ratchet (or hand rachet for the air-impaired) and get the bolts out. If you have the hood light...don't forget to disconnect that wire!
Old 03-15-2002 | 02:43 PM
88camaro's Avatar
yeah , i did , trust me , u better have ATLEAST one more person to take t off with . then when alighning it i think 2 ppl is enough .
and
where were u to save me !!!! lol,
i was lucky my windshield stayed in one piece tho
Old 03-15-2002 | 03:24 PM
86BIRD-MY FIRST CAR's Avatar
I got the same question, i do u remove the hood on a thirdgen bird?
Old 03-15-2002 | 05:43 PM
Jim85IROC's Avatar
Same way!
Seriously guys. This isn't the space shuttle. Stare at it for 5 seconds and if it's not totally obvious, you probably shouldn't be trying it anyway. There's 4 lousy bolts that you need to back out. That's it. Just have somebody help you with it and unbolt it one side at a time while you support it with 1 hand, and maybe rest your shoulder on the underside to balance it.
Old 03-15-2002 | 07:22 PM
bradkeith's Avatar
taking the hood off is very easy, just make sure you mark the hood/hinge relation with a marker. it'll save you time lining it back up. there are 4 10mm bolts. Me and a friend swapped the hoods on my camaros today in about 25 mins.
Old 03-16-2002 | 07:02 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i practice in the junkyard with blockbusters and coffee cans full of gasoline.this way when i go to do mine ive got it down pat
Old 03-16-2002 | 09:18 PM
mechanicalmehem's Avatar
hey 85SportCoupeto89RS is that an aftermarket nose or is it an original?, if it is afternarket, how well does it fit? Thanks
Frozer!!!
01-19-2024 05:55 PM
Vintageracer
01-10-2020 06:33 PM
Black89TA
Exterior Parts for Sale
07-23-2016 11:42 AM
Wife'sCar
08-22-2015 02:46 PM
3rdgenparts
08-08-2015 08:09 PM
Quick Reply: How do i remove my hood
