Headlight Knob Problem!!!
Old 03-12-2002 | 03:40 PM
StarOfLife's Avatar
Headlight **** Problem!!!
I have an 85 Z28 that I am doing some interior work to. I need to remove the plate that houses the controls for the headlights. The only problem is that I can not get the **** off of the bar and I do not want to exert force upon the bar as to cause it to break and be w/o headling controls! Could someone please tell me how to remove this ****! Thanx.
Old 03-12-2002 | 03:48 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
There is a button (quite small) on the switch unit itself that you have to press while pulling out the **** to release it. If I remember right, it's a real b---h to reach up under the dash to get to it.
Old 03-12-2002 | 04:40 PM
StarOfLife's Avatar
Oh thats just great! There a tech sheet or something I can find online to see what i am looking for?
Old 03-13-2002 | 03:30 PM
StarOfLife's Avatar
Ok, I am going to assume that the button that I am looking for is about the size of a small screw that has a spring on it, correct? Well I have found the button and when I press up on it, I can pull the headlight **** only back far enough to turn on the parking lights. If I release the pressure on the button and pull the **** back as far as it can go to engage the headlights, I can not push up on the button. Is there something I am not doing, or something i am doing incorrectly?
1992 Trans Am
05-10-2023 08:19 PM
GTAman
03-15-2019 12:40 PM
OLDYELLR
Car Audio
09-30-2015 08:10 PM
Fronzizzle
08-17-2015 03:52 PM
Tony Ferrarri
08-11-2015 08:59 PM
Quick Reply: Headlight Knob Problem!!!
