Headliner falling down.
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
I took off the black trim, i belive called a-pillar, which runs up above the window and after that the headliner started sagging. Is there a way to fix this without going to a shop. something I can do myself?? thanks
If it is just the material sagging, the help-it section at Auto Part stores sell a headliner support screw which just screws into the board to hold up the material. Or if you make a very small slit and spray some adhesive under the material and hold in place.
If it is the board itself.........it is not very hard to remove and repair/replace.
LT1Formula
10-08-2015 08:34 PM
3.8TransAM
10-01-2015 07:47 PM
formula00ra
Interior Parts Wanted
09-28-2015 11:50 AM
