Here's a stupid question.....
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
How do you take the shifter **** off for an auto 'bird? I'm trying to remove the console so i can fix a few cosmetic blemishes (the vinyl is starting to seperate from the sides). There's a little notch/opening on the front of the **** near the base but i don't know know what i have to do next.......
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Pop the cover off (if there is one) from the spot you described with a small screwdriver then pull the clip out. The handle pulls off after that.
Okay i tried pulling the little clip out with some needle-nose pliers but it won't budge. The pliers won't hold hard enough to let pull the sucker out. Is there any special trick to doing this?
Car: 91 Formula
Engine: 305 TBI
Red,
Can you let me know what you're planning to do to reattach that separating vinyl and how it works out for you? Thx!
gta892000
09-16-2015 12:37 AM
