im getting new springs to lower my car, help me out guys.
ok guys I don't know a damn thing about springs, i have an 84 camaro sport coupe with stock ride height, it looks so high off the ground it i hate it, i want to lower it enough so it looks agressive but at the same time i dont want to go over speed bumps at 5 inches an hour. i also want springs that will give me better shock absorbtion, it feels like a boat when I go over bumps, or do I have to get new shocks to fix that problem? how much would it run me for some good springs, im on a budget, oh and what else can i do to lower my car?
Car: 91 Firebird Vert
Engine: LO3
Here is my two. Both have been lowered and it was by using different springs. The Camaro has Intrax springs and the Formula has Sportline springs. Both ride rather firm, but I prefer the Intrax springs cause the ride is a little better.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
To lower a car properly I would recommend getting the front spindles that lower your car rather than getting shorter springs. In the rear there is no other choice for lowering your car, springs is all you can do.
If you just get shorter springs you change the geometry of your front suspension and you might be asking for some headaches in the future...
JOhn
JOhn
Engine: LO3
JOhn
JOhn
1992 Trans Am
05-10-2023 07:19 PM
