manual exterior mirror adjuster?
The 87' firebird drivers door mounted mirror adjuster is not functioning properly. I can move the little lever on the door around and the exterior door mirror moves only occasionally.
I've had the door panel off and see the mirror adjusting mechanism is linked to the mirror by three cables. Do the cables perhaps stretch over time?
Are there any tricks to fixing this common firebird problem?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 IROC-Z
Engine: 5.0 TPI
The problem may be in the mirror itself. The plate the glass attaches to may be loose or something. I had a Cutlass where the driver's mirror did the same thing, and the pass. mirror on my Camaro flaps around a little.
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
might need some lubrication, the cables will stretch a little if ther eis too much friction.
John
John
Hotrodboba400
12-10-2019 07:07 PM
86CamaroDan
09-29-2015 10:08 PM
tglennon11
Interior Parts Wanted
09-11-2015 10:25 PM
