Anyone have a GM part number for door handles?
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
outside handles
abbreviations
frt - Front
s/d - Side door?
o/s - outside?
w/o - Without.
I found these in the firebird parts manual
82-87 2332644 - RH - handle frt s/d o/s (Bright) (W/o clip)
82-87 2332645 - LH - handle frt s/d o/s (Bright) (W/o clip)
These are the ones you will probably need
82-92 2332646 - RH - handle, Frt s/d o/s (w/o clip) (black)
82-92 2332647 - LH - handle, Frt s/d o/s (w/o clip) (black)
hope that helps
abbreviations
frt - Front
s/d - Side door?
o/s - outside?
w/o - Without.
hope that helps
they might not make them anymore...
I got them right from the Parts & illustration catalogs, of course there might be a new part number that superceded these. I think they used those handles on just about everything from S-10's to Firebirds...
you might have to go through a salvage yard, usually there decent shape yet... give them a shot of semigloss black and go with it...
John
John
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
Are the doorhandles universal for the gm car line, except for trucks and the vette? Reason I ask is I broke the door handle on my celebrity once, and replaced it with the door handle from my wrecked cavalier. I seem to think that if it is the same side door, it would work from say a cavalier to a camaro.
Might be worth a shot.
NAPA, PepBoys, AutoZone, Advance Auto...etc etc....They can all get the doorhandles. Motormite is the vendor (the HELP line I believe) part #s for the left is 77048 and 77049 for the right. About $20 each.
Hope this helps.
Hope this helps.
well, i don't need just the handle. i actually need the tension springs and any small bits that go with the handle because mine are loose and rattle like crazy.
1992 Trans Am
05-10-2023 07:19 PM
IrocZ'85
08-17-2015 06:24 PM
TA8487
08-16-2015 12:21 PM
