Modded '86 Bird Gauge Template: Opinions
Location: "No one cares if you're in before the lock!" - Best quote ever.
Modded '87 Bird Gauge Template: Opinions
Basically, I've used Unforgiven's base model for the gauges, ncluding the colours, etc...some had to be resized, and sharpness was lost during the .jpg conversion, so I redid some of the text...finally, I figured the Bird lgo added to it. Opinions?
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Excellent! Let's see the other gauges, too
It is my hope that thirdgen members will soon have such excellent gauges to choose from that they won't have to do anything other than print these freebies
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
ahem!, the speedo is actually my work with the outline numbers, thought I would chip in and tell everone that...(Except for the bird, thats NOT mine...)
i alowed unforgiven to use them...
John
John
Sorry okfoz, I gave the credit to Unforgiven because I got them off of his site, didn't see any referral to who created them, so I assumed they were his. =) Thx!
nooo problemo...
John
John
Engine: 305-4v
Originally posted by Vikingbrew
are there any Iroc gauges?
Adjust its size until it prints out at 5 3/4 inches from one side of the grey circle to the other. It should then be close enough to work really well for you.
Engine: 305-4v
And here is a colourful Iroc Z tach. Set this one to print at precisely 5 1/2 inches from once side of the black circle to the other. Colour laser printers are best. Use good heavy 50 lb. paper if possible.
Engine: 305-4v
In case you need kilometers per hour, seeing as you are from BC. This will work perfectly on those 85 or 90 mph--or 140 kph-- gauges
Car: 82 Trans am
Engine: Twin turbo 350
azure, do you have a template of just the grey screaming chicken background? i would like to use it with your permission, but i have a 145 speedo. thanks
Hey, sure thing, I'll have to redo it again, but it's not difficult (I never actually saved that image...) Hit me with an email, azure@speedline.ca , and I'll send it to you ASAP.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
For the guy that wanted IROC gauges, I just uploaded mine to my webpage. The link is in the sig. I took the km/h numbers and also took out the spot for the trip meter since mine doesn't work, but I think they looks good.
Glowsock
09-06-2015 06:40 AM
