Question on Firebird Headlights
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
On my headlights, the motors etc work great, but when they are on, every time I hit a bump the beam wobbles up and down.
If you hold the headlamp assembly, you can physically swivel it up and down slightly.
Is there an adjustment I am missing?
Cheers
Richard
Cheers
Richard
Location: Doghouse ······································ Car: 1989 Formula 350 Vert Engine: 350 L98 Transmission: 700R4 Axle/Gears: B&W 3.27
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
There is a retainer that might be loose....
If it is JUST your headlight:
Raise your headlight.
Take off the black bezel around the headlight, there are 2 screws on each side of each headlight. (I think there T-15 torx)
Once that is off, there are Phillips #2 screws that can be tightened, on a ring that goes around the headlight.
If it is the entire assembly:
I would imagine the little bushings etc could be worn, or even your motor, could be wearing out. Open your hood and pay attention to where things stop moving, and concentrate on those areas. Thats the best i can do without seeing it.
John
John
1 Post
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
There are also 2 bolts on the bottom of the entire assembly, which you can get to from beneath the car. If they are loose or missing, that will cause that problem aswell. I had the same prob,and those 2 bolts fixed it right up!
1992 Trans Am
05-10-2023 07:19 PM
