T Top replacement
Old 01-11-2024 | 12:50 AM
thatsupnow's Avatar
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s480
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
T Top replacement
Hey guys so I'm looking to replace these lexan T Tops on my 91 with a nicer set of glass tops. I see most of them use a 3/8 pin where mine are these 3/4(?) pins that also appear to be spring loaded maybe.
What's the easiest way to do this?? Swap over the entire latch assembly or swap the body receivers for the smaller pins?? Thanks guys
Old 01-11-2024 | 03:43 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: T Top replacement
Just put the older ttops in your car..
You may have to adjust the receivers on the body side but they interchange no problem.
Not sure why the spring loaded plastic sleeves were added over the pins in the later cars. Think it happened about the same time the ttop seals got their last update.
Old 01-11-2024 | 10:25 AM
thatsupnow's Avatar
Oh perfect that definitely simplifies things! Thanks TTOP350
TTOP350 (01-11-2024)
Old 01-12-2024 | 05:14 PM
dm3k's Avatar
Car: 1989 iroc z
Engine: 5.7
Yes. The glass ones should fit no problem. I have my original Lexan and a backup set of glass ones.
Old 01-12-2024 | 05:26 PM
thatsupnow's Avatar
Sweet man my lexan tops are toast they look like ****
TrueIroc
11-20-2014 09:58 AM
chevydrvr
08-03-2014 02:11 PM
Lee1
06-25-2009 10:26 AM
86TARecaro
07-21-2007 10:25 PM
Darkshot
10-27-2006 09:43 PM
