bulge trans am hood
Old 01-10-2024 | 06:57 PM
petrolhead's Avatar
Car: '83 trans am Lear Siegler
bulge trans am hood
Does anyone else have a problem with water leaking into the air vent in the hood and onto the air cleaner? Any fixes for this?
Old 01-10-2024 | 07:07 PM
Firechicken82's Avatar
Car: 82 TA
Engine: Zz430 clone
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: bulge trans am hood
This has been an issue. On the ducting in the hood I believe there's a little drain. It can clog. I knew a guy in the 90s who had an 84 and it sat w all winter and the water ran into the air filter and into the engine. It worked out well for me, he sold me the car w a water logged engine for $125. I don't know if all the cars had the drain or not.
Old 01-11-2024 | 03:25 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Do you have the cold air induction setup or is yours blocked off?
either way, there is a foam seal for the scoop to hood and for the cold air induction cars, a draintray that bolts to the lower part of the screen under the hood.
Old 01-11-2024 | 11:36 AM
petrolhead's Avatar
I see, good to know, I've owned this car for 25 years and somehow didn't know that. Yes it's cold air induction. I will look for it, thank you
Old 01-11-2024 | 11:08 PM
TTOP350's Avatar
There's a great thread of all the parts used on here someplace but can't find it right now
Old 01-12-2024 | 05:49 AM
fteufert's Avatar
Car: 1982 T/A
Engine: 1973 400 Chevy
Transmission: 4 Speed Borg Warner
Axle/Gears: 3:23
https://www.thirdgen.org/forums/hist...-trans-am.html article with everything you need to know about the functional scoop
My car has the Drip rail (GM #10028254) which stopped that problem
Old 01-12-2024 | 12:38 PM
petrolhead's Avatar
Thats a great article, thank you. I tried doing a search, but I didn't come up with anything. I want to say my car is an earlier 83 car, so I'm curious if it has that drip rail of not. I should be able to look at it today.
Old 01-12-2024 | 06:57 PM
petrolhead's Avatar
Well I took a look at it, and it does have the part. It's clean and no clogs. We did have a heavy rain, maybe it was more than it could flow at the time.
Old 01-12-2024 | 09:59 PM
TTOP350's Avatar
The deteriorated foam seal can also let in a ton of water
Old 02-19-2024 | 02:08 PM
petrolhead's Avatar
I took the airbox out. I don't see a seal. Where is the seal located? Is it between the ornament and the hood?
92ZCONVERT
09-07-2008 02:28 PM
MoroteZ28
10-14-2005 11:10 AM
1bad92TA
08-09-2004 07:35 PM
