Body Falling Apart
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
Re: Body Falling Apart
Tire carcuss, I've seen it before.
mantaguy (11-29-2023)
Car: 92 Heritage Camaro Z28
Transmission: auto
Axle/Gears: 3.23 Limited Slip
Mine cracked and broke on my 92 z28. They are prone to that and the paint also fading differently than the actual body paint.
I call it GM's cheap *** plastic.
Engine: LS1, LB9, L03
My '91 T/A was like that when I got it, I figured someone opened the door on a high curb or something. Was able to fix it with a fiberglass patch, still holding 18 years later.
Engine: 4++,350 & 305 CIs
They are plastic, not fiberglass
