How to tell if frame is bent?
Old 02-12-2023 | 04:31 PM
DigitalCannon's Avatar
Hey everyone, I'm putting together an 87 firebird roller that I got and I'm concerned that the car was in an accident. I have a tubular k-member from Spohn and a wonderbar from Detroit Speed. The k member doesnt line up with the bolt holes once both alignment pins are in. The wonderbar almost has enough room to go in but its rubbing on the right frame rail so much that it doesnt fit. Judging by youtube videos of installation of either product there isn't supposed to be any of these problems.
So, how can I tell if the frame is bent?
Old 02-12-2023 | 04:37 PM
Tuned Performance's Avatar
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How to tell if frame is bent?
Put it on a frame machine, or look for bent structural parts
Old 02-12-2023 | 04:40 PM
Problem is the car is totally gutted in the front. No suspension, nothing. There's not much to go off of.
Old 02-12-2023 | 04:45 PM
Engine: Lb9
Transmission: M20
Only other option would be try a stock K member. Good luck
Old 02-12-2023 | 10:01 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Did GM not have a body manual for these cars with body/frame dimensions that can be measured?
Old 02-12-2023 | 10:36 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Yes, it's in this thread.
https://www.thirdgen.org/forums/susp...r-install.html
Old 02-12-2023 | 10:40 PM
Engine: Lb9
Transmission: M20
The following 2 users liked this post by Tuned Performance:
DynoDave43 (02-12-2023), SbFormula (02-13-2023)
Old 02-13-2023 | 01:51 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
It's in the GM service manual.
zstalker
02-24-2023 11:58 AM
Outlaw28
06-20-2008 05:00 AM
paulmoore
06-25-2006 11:56 PM
Farfire70
01-12-2005 05:44 AM
Scott_92RS
07-20-2001 12:22 AM
Quick Reply: How to tell if frame is bent?
