Door Handle Latch Rod Install
89 Camaro RS Convertible
I seem to have a hodge podge of latches & rods and i'm not sure what the correct install of the outside door handle latch rod should look like on the latch side itself, only goes one way on the door handle side.
I know it's hard to get any pictures of anything inside the door so i was wondering if someone had a latch already off a door they could take a picture or two of with the door latch rod installed and rough latch orientation as well when it's installed right.
driver or passenger side is fine.
thanks in advance.
thanks in advance.
Re: Door Handle Latch Rod Install
Perhaps the following will help. Check out the pics in posts 10 an 11.
https://www.thirdgen.org/forums/body...servation.html
JamesC
JamesC
