This is what happens when someone jacks up a camaro wrong
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Purchase a 1990 camaro Rs convertible, car is clean and rust free. Stock tbi 305 700r4.
I saw this issue when I purchased the car and it made me cringe as to the stupidity of people. I can only assume that the previous owner tried jacking the front of the car by jacking under the front clip/radiator framing. Needless to say, the framing pushed up probably a couple inches. Here is my little project of repairing the metal and getting it back to straight and strong.
This is the bent portion cut out.
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Re: This is what happens when someone jacks up a camaro wrong
Definitely cringe-worthy...
no new tires (07-06-2021)
Engine: Built ls1
Axle/Gears: 3:42
making some progress.
Engine: Built ls1
Axle/Gears: 3:42
Not perfect, but pretty damn close from how bent it was.
That’s a nice job. I think it’s tempting on these cars since they’re so low - I can’t get a floor (trolley) jack underneath mine when coming in from the side without taking the saddle off.
A nice, low profile 2.5-3 ton floor jack is a must for these cars at stock height, even more so when you're lowered.
Engine: Built ls1
Axle/Gears: 3:42
Battmann,
That is the same piece, I cut out the original one and straightened it out on my work bench with some “gentle massaging” and heat. Took me a few hours to get it straight and then I welded it back in.
