Man, my interior looks ragged,
Done, man oh man, well I'm eaither gonna stripe this one for part and sell it off, sell it as a whole, or i dunno.
I'm gonna have to use the spare car for awhile and probably keep my eye out for an IROC or 300ZX
Zepher -
I am a strong believer of keeping your project on the road (as much as possible)!!! If you are like me the longer it sits the colder it gets... but I will have to say that I have scrapped some rolling projects!
69' Chevelle 2dr Malibu - Owned for 1yr - decided that I should cut my losses and send it packin' - found a 69' ElCamino
69' El-Camino - Finished, given to my brother (355 cid, Muncie 4sp, 12 bolt)
80' Trans Am - 301 auto perfect body - sent it packin after it sat for a year (running car, no time, just got married, thought my life was over)
80' Jeep CJ5 (still dont know why I bought it) - owned it for a summer, had fun on the NC beaches - cold weather, didn't move from nov' - march' - good bye
Now I got the 89 convert. may fav car yet - needs alot of work, but it's what I like to do.
Drive a 95' Monte Carlo Z-34 Brickyard (#299 of 400)
Like the seats, looking forward to seeing the end product.
KEEP UP THE GOOD WORK MAN
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Thanks,
I got the motor started using starter fluid tonight.
Seems that the injectors aren't spraying any gas.
Need to find out why.
I needed to get the old ground FX holes filled so I needed to take the door panels off.
The wires are all over the place due to the Carb to TPI conversion. There is a lot of wiring invloved.
I had my antenna hole shaved and the gfx holes filled, here are a few pics,
I still need to finish up the other 6 holes from the old rocker panels.
my good lord, is that a hole in the front passenger fender?
have you decided on what your going to do for a radio reception now?
i changed the word *** to lord........hope that works better.
There's always been a hole in the fenders.
That is where the Air Extractors go.
About the antenna, I am going to go with one that goes on the inside window.
Damn, looking good man, looking good. I've got a giant parts bucket in my drive way if anyone is interested, lol.
I think I'm gonna plan my next project! Whens this bad boy gonna be ready for the street Zepher?
I should be able to get my hatch on Saturday, guy has 3 of for sale for $50 each and they are in really good condition.
If I can figure out why the injectors don't fire, which is really the only problem I am having, then she'll be able to be driven on the street.
Oh, I also need a y-pipe made up, can't go driving around with open headers, it's kinda loud.
Originally posted by Ions91Z28
Hmmm...zepher... I do believe your car has been sitting too long.
One of my friends wrote that there, it wasn't me.
I am not too concerned with the radio since I mostly listen to my CD changer. All I need is good reception of one station, 94.9.
Car: 1991 Camaro Z28
I wouldn't worry about radio. I shaved my antenna... haven't had any problems. Radio has to many bad songs for every good song. Easier for me to burn the cd and just listen to it when I want. Despite it being gone, no one has noticed it not being there. But when it was there, everyone said I should cut it or buy a new one.
Car: 1987 GTA
Transmission: 4L60e
Hey Zeph...does the car run ok after it is started with the starter fluid?? Mine got like that. Check the fuel pressure. My bet is that it's too low...mine was around 35-38 psi. 1 new fuel pump later...it's running fine. It could be other things though...but this is what happened to me.
Good luck.
MAN OH MAN those gfx look great on a TA!
Good luck.
Pump is a brand new Holley in-line pump.
I know for a fact that the injectors aren't getting the pulse that they are supposed to get.
My ECM checked out great as well as my custom chip.
I think it is the Distributor.
Gonna check that tomorrow.
I dunno what the hell to do with mine, i need to get under the hood and fiddle with the engine for awhile to figure out what i can do. If i can get teh bitch running, I'll sell it fast to the next poor SOB. Otherwise I'll part it out.
Well, keep us informed.
I need to get cracking on my car.
Maybe it'll be running by Sunday, we have an all day dyno tune scheduled from 8am till we are done.
Car: 1984 Pontiac Firebird
Engine: 2.5L Iron Duke 4 cylinder
Transmission: 5 speed manual
Where on earth are you guys getting the 4th gen parts for your thirdgens???
I found a set of seats for my 84 firebird but it was a blessing. There are NO 4th gens in my local yards.
How much did you give for the rims???? Console?? Leather Seats??
billsfirebird
billsfirebird
I gave $225 to a friend for the wheels.
$75 for the AutoShifter Console to the Junkyard.
$45 to a guy on LS1.com for the 6 speed Shift Plate
$650 for the Mint condition 96 Camaro SS Leather Seats, but the ones in my car aren't the ones I paid $650 for. My brother and I swapped Leather seats from his 96 Trans Am.
I try to get my parts locally if I can.
If you want to order parts, call up SpeedAutomotive, they deal in 4th gen cars. www.speedautomotive.com
That is where I got my Leather Seats.
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
gfx q
hey zeph, are those gfx off a 90-92 camaro? those look really good, i am assuming they mount different. your car is a work in progress, and theres nothing wrong with that, you should see pics of mine........oh boy
Those side skirts are off of a 91-92 Camaro.
The rocker panel mounts the same, the door pieces mount a little lower so I had to drill 3 new holes on each side and fill in the old 3 holes.
I also have to fill the 3 holes on each side from the 86 Rocker panel as well.
Car: 1982 Firebird
Engine: sbc 307
Transmission: 200
How'd you guys fill the antenna hole? Did you weld it or bondo or what? Also, what all is to shaving the antenna, I think it looks so much better and very clean. Thanks.
Car: '82 Z28
the joys of kitty hair used that stuff to fill in the tiny holes from taking off the door trim on mine. Also used it quite a bit on the last little project, a dune buggy tons of small holes from different things over the years.
Originally posted by LottaBallsCamaro
Zeph...How are you plumbing the air vents behind the front wheels???
Mot sure when they came out in the 4th gens, but the seats in my friends 91 GTA look almost like the 96 Trans Am seats I have.
Originally posted by 72BuickGSX
hummm want to sell that dual ram air box, , been looking for one,
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
"air extractors"
where could I get those vents, i would like to put them on my camaro. (ruling out the boneyards, i already took anything of value of my local ones)
#42
My SOB is running, I upped to 92 octane, some of the connections around the terminal looked like there were all purposely unplugged. I wonder if those guys who towed me home did this purposely knowing I needed to get from Richmond to Virginia Beach, here they are saying my engine is shot, and after inspecting it on the home front and tighting the flexplate bolts to the crank all of the noise and engine symptoms are gone. Also replaced the fuel filter which was pretty clogged. Running damn hard and strong. However I am still going to sell her now, and look for something else. But she won't be parted out since I can get money outta her now.
#43
Re: "air extractors"
#46
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Re: Re: "air extractors"
If you are talking about the holes that are in the fender on the Trans Am's, just cut a hole. I can get you 2 new air extractors for $40.
#47
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Don't feel bad Zepher... my interior is in as bad of shape (if not worse) than yours...
bubbaz28
09-18-2015 03:09 PM
