who here has replaced their door hinge pin thingys?
who here has done it by them selves? i have read the info at 3rdgensolutions.com or whatever the site is, however i would like some more feedback on how easy this is and stuff.
I have replaced the pin and bushings on a 78 camaro. I'm sure its about the same. You should be able to get a kit at Advanced Auto. Just knock the old pin out and put the new stuff in. Its kind of awkward with a jack under the door. Its a pretty straight-forward operation though.
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Like "breathment" said, "check out www.3rdgensolutions.com "
Several members have the 3gs UPPER kit.
Thanx,ANDYZ28
PAIN IN THE ***!!!!!!!!!!!!!!!!1 my and my dad did it damn i hated doing that we replaced the whole hinge grrrrrrr took 4 ever and my dad is a expert at this
Car: 1982 Z-28
As I said,"it is much easier to replace just the UPPER hinge pins & bushings instead of the entire hinge."
Took about 3.5 hours for each door the first time (my Trans Am).
Car: 1982 Z-28
Originally posted by 82Trans Man
He ASKED for someone whos done it. Obviously you haven't done pins and bushings on a Third Gen. Take a look next time you get in your car. The upper hige has huge factory rivets. I did it on both of my doors as well as a customers while I was working at the Chevrolet dealership and I know that its impossibe to get the pins. The best way I know to do it is put a 2X4 on a hydralic jack and lift till it comes into contact unbolt top till finger tight or should it be finger loose?? Pop the bottom pin and then unbolt top. Cut the factory hinge off. Place template from hinge kit and drill holes if you didn't tear too much doorskin if so weld a new piece of tin on and place template on drill place braket behind may require a little trimming then bolt new hinge on. Use the larger oversized bushings for bottom hinge.
Thanx,ANDYZ28
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I did my drivers side pin and bushings.
I had to drill a larger hole in the bottom hole and but a bushing in there, there wasn't one to begin with and that hole was elongated.
I put a jack under the door to support it and took the door off and balanced it carefully while I did the work.
I had to take it to the dealer to get the spring back in, I tried for an hour to do it so I just said *** it, and took it in. took the guy 15 seconds to pop it in.
1992 Trans Am
05-10-2023 07:19 PM
