Cowl rust?
Re: Cowl rust?
My answer is always the same. Sandblast as much as you can. Spot blasters are cheap. Remove that seam sealer and get as much as you can with a blaster and wire wheel/wire brush. After that maybe chemicals will help with the rest.
when you’re done seal it with epoxy primer. You can spray it or brush it on, then cover it with seam sealer.
Car: '89 GTA
Engine: ZZ6TPI
Re: Cowl rust?
There is definitely more than surface rust in there. You will need to get in there with any tool that you can (screwdriver, gasket scraper, putty knife, whatever) and dig and scrape the old seam sealer out. Then, use a spot sandblaster to get all of the rust out and see what you are dealing with. More than likely, you are going to find some holes and rust/rot down in the seam where multiple pieces of Sheetmetal are spot welded together. If that's the case, then the only correct way to fix it is to cut out the rusty metal, fabricate new pieces and weld it back together. Then epoxy primer, new seam sealer and paint.
I would seriously take a look at the rest of the common rust areas of these cars and evaluate whether or not it makes sense to continue down this road. Based on how that cowl looks, I would suspect there is a lot more rust elsewhere.
Re: Cowl rust?
If that looks like that, look really close where the front wheel tubs come back and down to where they meet the firewall. Pretty good chance you'll find rust in those corners.
I got a set of chisel scrapers from HF, then sharpened them razor sharp. A set of scratch awls with the various hooks, etc can come in handy removing the old crapped seam sealer. Once all that is out, you'll need to get busy with the sand paper, wire brushes, sand blaster, etc. If all else fails you could cut steel and open up the area to allow access, then weld it back up when you're finished.
Re: Cowl rust?
Re: Cowl rust?
Re: Cowl rust?
Ya there rust here as well but this i can see behind and in front and seems like a smaller patch job on my end...
birdman_29
07-26-2023 05:24 PM
