Please help explain these cracks.
Hi all. I've posted many posts regarding my car, and appreciate all the knowledge the users and this site provides. I've come across a few more things of concern and I being a novice have never seen before... as i tear apart this 86 camaroI, I noticed a few cracks that I myself cannot explain. I'm hoping someone has seen these before and can advise me if this is fixable or is this car scrap metal! The first pics are where the gear shift boot come up thru the floor and attaches to the gear boot, the other one is the top rear drivers side where the T roof attaches. Thoughts? Is this car done? Something to note there appears to be no damage to this car in the front or underneath. It has a clear title with no claims against it.
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: Please help explain these cracks.
Just because you have a clean history and or the underside doesn't appear to show damage, it still could have been rear ended or went up a curb, just a guess
scooter (09-06-2019)
Engine: LB9 305
Transmission: AT
Not good, but if the rest of the unibody is good(examine it on a lift) I'd have it welded and gusseted and go on. Couple small gussets.
Body flex basically, pretty common on these cars.Especially the b-pillar at the t-top.Even HT crack there, sometimes.Drill a small hole if front of the crack to keep it from getting longer.Then weld them up.The metal kinda looks a little tweaked at the shifter, but not 100% on that.Definitely not scrap material.
dmccain (09-06-2019)
The shifter area does look a little tweaked. I can compare to my car later and see what it looks like since my carpet is out. It may just look like that in the pic though.
Thanks What are you guys referring to the term tweaked? Is it Torque from the transmission? I realize were just guessing here. Just wondering if it's a safety issue.
Drilling a hole at the end of a migrating crack helps to stop the crack from going any further. Fill hole and the rest of the crack with a good weld.
WildCard600 (09-07-2019)
COTM Editor
Received 1,890 Likes
Car: '89 Firebird
Engine: 7.0L
The crack will keep propagating even if you weld it up, so you need to send the crack into a dead end cul de sac where it can't run any further. That's the purpose of the holes.
On Probation
What about the famous center dash face crack?
Heres another thread with pics:
https://www.thirdgen.org/forums/inte...or-issues.html
I can’t defend the cars. I like the cars, but man they were put together cheap. Same thing for 4th gens. I just wish they would have made the t top and convertible cars with factory subframe connectors and used better/different material for the dash and consoles. I love the look of the 3rd gen interior but I’m always being careful not to break something.
F-body driver
02-14-2019 08:05 AM
89fast5oh
05-24-2017 08:38 PM
86bird_28v6_5spd_ramair
11-29-2001 11:33 PM
