Does the Vynyl Repair Kit From Pepboys Work on the dash?
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
Car: 82 Camaro Z28
Engine: LU5 - Crossfire 305
Transmission: 200c - 3 Speed Automatic
i havent seen the kit myself, but assuming that the dash is not bumpy and any cracks r filled and sanded down, it should work. is the kit to repair a vinyl dash? if so, then i would have no idea.
mike (loomdog)
mike (loomdog)
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
it is a vinyl and leather repair kit and i was just curious if it worked on our dash to repair the cracks from exposure to the sun
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
When I bought my 92 RS, the dash had a crack on the corner of the driver's side so my dad bought one of those kits. It didn't work. It looked better than it did, but still no where near great. If you have a crack on the flat part of the dash pad, it can work. It comes with textured pieces, so you just mix up the goop stuff, but it in the crak over a piece of material they give you, put the textured thing on it and heat it. If you have a crack on a corner, I wouldn't try it, its a real pain. Good luck.
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
i have two cracks, one on each side, from top to bottom and just like you the corner is torn and barely hangin on, i can aford to buy a new dash pad now, its at least couple months down my list, so i was looking for a temporary solution to fix that ugly pad. any suggestion on what to do?
Car: 1989 IROC-Z
Engine: 383 stroker
Well with the kit and some time you can probably get the 2 cracks from top to bottom to not look that bad at all, if you're really determined you can probably get it looking normal. But the corners are really difficult to work with, so my advice is electrical tape
Actually, electrical tape won't stick to the dash, so I guess you're outta luck.
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
tried electrical tape on the corner, doesn't stick to the das thouh, i might try to use my black silicone sealant but not sure if i want to or not. what do you think?
Terrell351
06-13-2021 01:13 PM
The_Phoenix
02-04-2016 07:10 AM
