Repair or Replace Ground Effects
I have not dealt with ground effect issues like this before. The car is a 1984 Trans Am with the Aero Package. The front portion has damage and I don't know if it's repairable. One of the issues is that these are difficult to locate as they are not very common. Thoughts?
Re: Repair or Replace Ground Effects
Anything's "repairable" with the right amount of time and money. I've had good results just using Bondo fiberglass repair kits on ground effects.
Car: 1987 Trans am GTA
Engine: 5.7 liter
this is from an 82-84 trans am, all paint is removed, assuming it's the same
(edit: in looking closer at your pics I dont think it's the same, sorry)
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
i use evercoat maxim 2 part epoxy for urethane,
3m makes some too.
3m makes some too.
