E36 headlights like they should be
Old 06-13-2019 | 10:46 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44, Tru Trac, 3:73 gears
While waiting for my exhaust system to come back from being powder coated, I decided to knock out the E36 headlights modification. The BMW headlight buckets were grafted to the Camaro fiberglass headlight support. I wanted to do minimal cutting to the radiator bulkhead and maintain the original fender mounts. I feel it looks like an OEM installation.
Old 06-15-2019 | 02:03 PM
Destro Camaro's Avatar
Car: 88 Camaro
Engine: 2.8 V6 For Now
Re: E36 headlights like they should be
Looks good! Defiantly one of the cleanest headlight swaps.
Old 06-21-2019 | 10:49 AM
85RS's Avatar
Car: 85 Camaro RS
Engine: GEN I sbc 5.7, .040 over
Transmission: 700R4 Slushbox dreamkiller
Axle/Gears: 3.42 posi
Somebody needs to write a sticky on this.
Old 06-21-2019 | 10:51 AM
kaos420's Avatar
Car: 88 gta
Engine: 5.8
Axle/Gears: 3.73 POSI
NICE JOB
Old 07-27-2019 | 01:46 AM
Z03Z28's Avatar
Car: 92Z28,98LegacyGT,ZX9R,91 Z28,02 Z71
Engine: 350,307,2.5,900cc,5.0
Transmission: 700r4,4spd auto,700r4,4L80
Axle/Gears: 323,?,323,?,373
Awesome job.
Old 07-27-2019 | 01:28 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Sorry to rain on your parade, especially since you did it better than most, but anything that hacks up the core support without welding it back up and reinforcing it somehow isn't how it should be. The E36 headlights still don't fill up the headlight buckets. Nowadays that headlight mod is outdated when you can just open up the back of the headlight clam (Nothing structural cut and you can still swap back and the entire project can be done in an hour) and install a set of these LED projectors.
Old 01-10-2024 | 12:08 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
This does look to be one of the cleanest headlight swaps i've seen.
How much was actually cut away besides the notches up top. I got a firebird so dont know how stock support is on this.
Wonder how it looked when all finished with the hood on.
Old 01-10-2024 | 07:12 PM
soloc4's Avatar
In the end I made some modifications to the light housings to extend them 3/4” out to better align with the edge of the hood. I also cut out the hump where the hood bumpers were and made them flush on top. There were notches cut outboard of the outer headlight cutout, this can be seen in the older pictures. Finally, a fiberglass nose was used on this car and the entire headlight bezel was bonded to the inside to create a true bolt on front fascia. The fiberglass nose, headlights, turn signal lens, and the grill are one piece. I recently added close out panels on top of the light housings.
One piece assembly
The headlights fitted to the fiberglass fascia
Hood alignment
Without close outs
Added close out panels
This modification in no way compromises the integrity of the core support. There are multiple unused holes throughout the core support from the factory and it is not a structural component.
Old 01-10-2024 | 07:28 PM
Axle/Gears: Stock
Real nice work there if someone didnt know, they would think its factory.👍
Old 01-10-2024 | 09:05 PM
Axle/Gears: Stock
By the way what suspension are u running there, looks like missing some strut mounts.
Old 01-10-2024 | 09:41 PM
soloc4's Avatar
C4 Corvette front and rear. You can see the build thread here in the Camaro Forum under
“1 of 1 Z28”. You can also search “SoloC4” for more of my work.
Old 01-10-2024 | 09:47 PM
Axle/Gears: Stock
Cool i'll check it out.
LiquidBlue
06-13-2019 12:06 AM
black88cam
05-11-2014 03:17 PM
lillee64
Fabrication
41
08-14-2011 01:51 AM
Sinister Z
Members Camaros
50
03-22-2011 09:37 AM
AmorgetRS
04-22-2001 02:20 AM
