3rd gen camaro how to remove door glass without power
Old 02-04-2019 | 08:02 PM
Bohemian's Avatar
Is there a way to remove door glass from a 3rd gen camaro without power?
mine is a 89 RS Convertible with power windows, I have the engine out, getting car ready to be repainted and I need to pull door glass without power IF it's possible.
thanks in advance
Old 02-05-2019 | 06:54 AM
the_assman's Avatar
Car: 90 vert
Re: 3rd gen camaro how to remove door glass without power
you could use a battery charger or jump box with a couple of pieces of wire to move the window up or down to be able to get to the rivets.
pull the connector off of the motor and touch the leads from your charger/jump box to the leads on the motor , one way will make it go up and one way will make it go down.
Old 02-05-2019 | 10:20 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
This, or you can jump the window switch if you can't get the door panels off
Old 02-05-2019 | 03:34 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Jumping the window switch works using a cordless drill battery.
adamlinn13
11-29-2012 11:20 AM
82firebird
09-23-2007 12:29 PM
Mikos_89
06-23-2003 09:26 PM
Quick Reply: 3rd gen camaro how to remove door glass without power
