Extracting hot air from underhood
COTM Editor
Received 1,917 Likes
Car: '89 Firebird
Engine: 7.0L
Anybody seen some slick ways to extract hot air from engine bay without doing stupid things to the hood? 1989 Firebird.
Thought about removing the cowl seal across the back of the hood.
Car: '83 Firebird (T/A Clone)
Engine: 350 carbed with L-69 components
Transmission: 700R-4 w/2000 RPM stall converter
Axle/Gears: 10-bolt/3.73 ..
Re: Extracting hot air from underhood
The passenger-side vent on Trans Am fenders is functional, so T/A fenders might be the ticket...
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I don't think that is going to pull air from engine bay. It is too isolated to the lower fender well.
Removing the cowl seal is a good way to pull any smells from under the hood into the fresh air vent. Also anything leaking under the hood can end up all over the windshield. Not to mention the hood will probably shake more.
With all the stock baffling under the front end and around the radiator, the airflow should come through the radiator, over the engine, down the trans tunnel and out. The only time any kind of exit in the hood will do much, is when the car is stationary.
Formula hood. It's the only way to be sure.
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
To Drew's point on how the air flows through the engine bay. What if you put 2 electric fans on the lower firewall on each side of the engine, face them down and back so the hot air will "Flow" through and out under the car. You may have to get creative with some sort of bracket for the fans but the theory sounds like it will work.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I didn't think about the window fogging up. Good feedback, guys. I appreciate it and more ideas are welcome.
Car: 89 Firebird
Engine: 355 TBI
Formula hood and remove block-off plate. You can put your hand there and feel the heat exiting.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Sorry, I should have mentioned "cheap" too.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
No more ideas?
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Appreciate the idea but that would be ugly as sin on my Firebird.
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Couldn't have said it better myself.
dimented24x7
12-04-2005 11:45 PM
