Turn signal mod question
Old 04-29-2018 | 09:11 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
So I am replacing my running light in front with LED strips and the turn signal as well. So wired them up. Two strips to the red wire on the turn signal lead, and to the black. Wired two more to yellow lead and black. The two strips wired to red and black come on when headlights or running lights are on as intended. The other two strips wired to yellow and black which are supposed to be turn signals come on when the turn signal is switched on but DO NOT BLINK!
So what do yall think? Do I have my wiring wrong? Or do need to add a resistor to the blink circuit? Or is my resistance too high? Ideas anybody?
LEDs are 12 volt auto motive use BTW
Old 04-29-2018 | 09:20 PM
Jp's camaro's Avatar
Car: 1991 rs, 1985 z28
Engine: 3.1 v6, 305 tpi
Transmission: 700r4, 700r4
Axle/Gears: 3.23, 3.23
Re: Turn signal mod question
If I recall correctly I heard something about having to maybe change the flasher to a different type
Old 04-29-2018 | 09:49 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Possible I suppose maybe the ground also however I wonder because I do sometime have blink issues with the bulb with the head lights on.
Firebat
04-25-2008 12:03 PM
pasky
05-27-2004 05:56 PM
Jetmeck
02-14-2004 04:10 PM
makinemtap
07-31-2001 09:14 PM
Quick Reply: Turn signal mod question
