for people with sagging doors.
i had the problem of saging doors and everyplace wanted 60-100 dollars so i decided to go to canadian tire and come to find out you can get upper and lower kits for under 20 dollars canadian so you us people its like $13.just thought i would let you guys know.
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
If you can send me one of the UPPER kits I will gladly pay you for it. But I think you will find that the UPPER kit will not work.
All of the UPPER dor hinge kits that I have seen (exept mine) are merely Lower pin and bushings. That's what happened when I bought the repair kit that was suggested by another member.
But I would be happy to see their kit.
Thanx,ANDYZ28
Thanx,ANDYZ28
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
ill be interested in buyin all four (both lower and upper) and will send you the money fo that price, ...man if it works for that price...
Car: 1982 Z-28
88greyiroc, Thanx a lot. Any possibility of a picture of them? Digital would be nice.
Car: 1982 Z-28
If we can find a volunteer to post them. You can Email them to him and he will post them for you.
Car: 77 Corvette
Engine: ZZ3/nitrous
Transmission: THM 400
I purchased two kits from Andy, havent installed them yet, but the kit is very complete, and the quality of the materials is first class.
If you are going to do something, then do it properly.
Cheers
Richard
Cheers
Richard
Car: 1982 Z-28
Check this out https://www.thirdgen.org/techbb2/sho...threadid=74756
Car: 94 Camaro
Engine: 3.4L
Transmission: 4l60e
what does yours cost andy, i remember reading your posts a while back, i believe they were like $60 a peice right?
all i know is the book they ordered it out of said upper hinge repair kit and lower hinge repair kit i can't see why they would make them if they didn't work????but as soon as i get it on monday i will let you guys know what it looks like.the kit from andy i thinkis a bit overpriced for me to get it would be like 150 canadian. and my way i paid 20 dollars canadian.
.350" ID X .500"OD
.350" ID X .406"OD
it says you have to replace the bushing before the pin is damaged.there are no pins just the bushings.
.350" ID X .406"OD
Car: 1982 Z-28
I don't think they will be of much help to you. I measured the diminsions of new GM bushings. Heae they are:
LOWER door hinge bushings GM part# 20429500 ID .354"/OD .419"
UPPER bushings are right around ID .600"/OD .712" I have to estimate the original GM UPPER hinge bushing diminsions. Because I have newer seen any that were not worn completely out. But I am not off by more than .004". The replacement bushings that I provide are thicker and stronger than the original GM upper bushings.
Odd that they would sell the bushings without the pins. You could always get a replacement LOWER door hinge pin from GM part# 20043351. But I know of no place to get the UPPER door hinge pins & bushings except from me. www.3rdgensolutions.com
I hope these GM part #s will be of some help.
Thanx,ANDYZ28
Thanx,ANDYZ28
Pac J
05-17-2020 10:44 AM
