Spring cleaning
Car: 1987 Iroc-Z Camaro
Transmission: 5-Speed
Axle/Gears: 9 Bolt Borg Warner 3.45 Gears
Spring cleaning
Today I took a couple hours and cleaned up my car and recovered it until the roads get cleaned up. I attached some pictures, I hope to see some third gens out and about this year. The door panels are off because i was replacing the top rails on the inner window.
Re: Spring cleaning
I am looking forward to driving mine around once in awhile also!
Re: Spring cleaning
I like your cover, where did you get it?
Car: 91 Z28
Engine: Enhanced 5.0L
Axle/Gears: 3:42 Posi
Re: Spring cleaning
I have put 300 miles on my car in the past 3 years...so I thought my car was CLEAN....until I removed my top radiator supports to look behind my radiator(motor side)...and GLAD I did!..Candy wrappers and leaves and stuff at the bottom of radiator....so if your car sees more mileage than mine, I recommend to everyone to look here...you'll need a long rod of sorts to move stuff loose..and an air compressor to shoot it outta the gap.....can only help keep it that much cooler!
