Part number for hood release cable clips?
I've misplaced my hood release cable mounting clips on my 90 iroc. Does anybody know the part number for them? Or a possible source to get new ones?
Re: Part number for hood release cable clips?
If GM no longer has them, you can try browsing this site. I looked through the GM section and came up zero. Doesn't mean that other mfgs. didn't use the same clip.
http://www.clipsandfasteners.com/default.asp
You'll pay more in shipping from gmpartsdirect than if you just go to a few local GM dealers and ASK for the reduced rate. It's not hard to find a decent counter guy.
At nearly $14 postage and $4 each for a clip, it should be easy to get them local for less.
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
I couldnt find one when mine broke (where was this thread a year ago) .... SO... I machined a piece of aluminum with set screws. Made it capable of holding two cables: One for the manual factory hood release cable and another attached to a 35lb pop solenoid. This allows me to give it a modern spin while having an override should the battery be dead.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Drew's right,GMPARTSDIRECT is a GM Car dealer.save the shipping fee.I practically restored my car from my local GM Dealer.
