Found where waters getting in, what sealant should I use?
I just replaced the passenger floor pan in my trans am, I found that water has been coming in through the ecm wiring port behind the passenger side kick panel. Should I just use seam seal to seal this or is there a better alternative?
Axle/Gears: 10 Bolt 2.73 Open
Re: Found where waters getting in, what sealant should I use?
Mine leaked there too. A dealer had smeared a lot of silicone over the area, but missed the leak.
To supplement the factory foam gasket, I rolled a thin bead of dum-dum out by hand, and applied it on top of the foam gasket. Spread out real nice when the pass-through was reinstalled in the cowl side panel.
Here's the product.
And here's a thin bead of it rolled out, and applied to the edge of a speaker for the dash, to prevent rattles.
Here's the product.
bbtaz97
Aftermarket Product Review
10-30-2001 08:50 PM
