Removing studs from spoiler
Old 07-15-2016 | 04:41 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have the 91/92 Z/28 high rise spoiler that I have been "adapting" to work for a 91 convertible Z/28.
(My thread where it really starts is here: https://www.thirdgen.org/forums/memb...ml#post6052704)
As you can see from the picture my latest issue is that the ends of the spoiler are a little short or the middle posts are too long. I think the best way to fix this is to remove the original mounting studs, shave down the middle posts and put in new studs but I don't know how to remove the original studs without butchering the bottom of the posts. Can anybody help explain?
My other solution (which I still may pursue if I can't easily remove the studs) is to lengthen and refiberglass the ends of the spoiler. That would easily add several more hours of work to this project.
EDIT: I've tried reaching out to this member who created the thread that gave me the inspiration but it seems he has litterally said goodbye to the thirdgen community. https://www.thirdgen.org/forums/conv...ml#post4929885
Old 07-16-2016 | 12:44 AM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: Removing studs from spoiler
It looks like Bluzee adapted his hi rise spoiler to the existing convertible spoiler side pieces which seems to be making up the gap difference that you are experiencing.
Old 07-16-2016 | 01:09 AM
Tibo's Avatar
Car: 1991 Z28 Vert
He did, but he also stated in a post the he removed the studs from the center posts and used longer studs-- which is what I'm trying to find out.
Old 07-16-2016 | 09:03 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
You might be able to put 2 nuts on the stud and lock them together. Then use the "bottom" one(closest to spoiler) to turn the stud out.
Old 07-16-2016 | 10:58 AM
Tibo's Avatar
Car: 1991 Z28 Vert
O not a bad idea. I had tried vise grips thinking "How good of a hold can fiberglass have?" Turns out the answer is pretty good. Vise grips were just stripping the nut and when I tried to rock it a little I could hear/see the fiberglass an inch away start to crack. I'll give the two nuts a try and if it fails I guess I can just add some fiberglass to the spoiler's ends.
chazman
05-07-2016 08:03 PM
789roby789
Carburetors
29
04-09-2016 09:09 AM
Tony P
04-03-2016 06:19 PM
Falcon50
03-30-2016 03:20 PM
JPrevost
Aftermarket Product Review
08-25-2001 12:37 PM
