Any special tools to bring to pull fenders?
Engine: LB9 305
Transmission: AT
Hi. Gonna go Camaro front fender, spoiler, bumper cover hunting @ junkyard.
Other than wrenches and sockets, shall I bring any other tools?
Torx bits? Thanks.
Torx bits? Thanks.
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Any special tools to bring to pull fenders?
Wire cutters and flat head screw driver for sure. To remove the fender the hood has to come off in addition to its brackets. The front bumper cover, bumprs's ground effects, all that air damn plastic and possibly the side ground effects. It's a time consuming job.
Car: '84 Firebird TA & '87 Camaro LT
Engine: 350 V-8 & V-6
Axle/Gears: 3.23 & 3.42
10mm deep well socket, 6"extension, universal joint and a large amount of patience to get the nuts off the studs on the bumper cover. Not much room in the front of the fenders.
Engine: LB9 305
Transmission: AT
Wow, thanks for the quick response's! I think I'll wait a day till my son can go with me.
Car: 1991 Z28 Vert
If you have a cordless drill/driver or driver or cordless ratchet or cordless impact it will make the job go much faster for removing the nuts on top of the fender and the nuts under the bumper for the plastic and ground effects. The 10mm ones already mentioned.
