Painting plastics question...
Car: 1986 IROC Z
So I'm in the sanding stage on my paint project and have removed all GFX and front and rear bumper covers. As I started sanding I realized I have to go all the way down to bare plastic on the front spoiler and bumpers to get rid of the cracks in the old paint.
I would assume I need to add a flex agent to my primer and base but should that plastic be painted or treated with anything else before primer? I noticed there were a lot of layers of primer or paint under the base coat on the front spoiler.
Re: Painting plastics question...
I'm more or less in the same stages right now. From what I have read, modern paints shouldn't require a flex agent, and adding it only helps for about 6 months.
I've also seen some people swear by using Bulldog adhesion promoter, and others that downright hate it. It certainly doesn't seem very clear-cut.
Car: 1986 IROC Z
I'm mostly concerned with reassembly. The front spoiler and rear bumper cover in particular are very flimsy or "bendy" if that's a word..
Only piece you could really argue for flex additive is the chin spoiler. The thing is a noodle when not mounted. The bumpers are fine as long as you use caution when handling them. As a side, my chin spoiler without flex additive after I sprayed primer bent 90* when the paint cracked.
jeremy iroc z28
06-28-2016 12:55 PM
mikeceli
06-14-2016 10:23 AM
