body moldings
Car: 1991 Z28
Engine: LB9 TPI 305
Transmission: MK6/MM5/ T5
Axle/Gears: GU6/G80/G92
body moldings
Is there a DIY way to fix plastic door moldings? mine have cupped and look really bad.
Axle/Gears: 10 Bolt 2.73 Open
Re: body moldings
Being in the Body section, and titled "Body Moldings", I assumed he meant the body side molding on the exterior of the vehicle. But you know what happens when you assume...
Car: 1991 Z28
Engine: LB9 TPI 305
Re: body moldings
I posted it in body meaning exterior moldings, specifically the ones that run along the bottom of the door to match the ground effects on my '91 Z28. They seem to be curling away form the door. If pictures will help I will get them, but it may take a few days (its at my dads shop).
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: body moldings
Earlier gfx are composite material & easy to fix with fiberglass.Not sure what later styles are made of, read they're more like the bumper covers, if so I would try a heat gun to soften it & bend back into position.
scarr001
03-06-2016 07:20 PM
xbazzarex
02-20-2016 09:08 PM
