how to get power window down?
Old 01-22-2016 | 09:48 PM
L-Train8's Avatar
Car: 1990 Trans Am GTA
I picked up a door off of a parted out Firebird on craigslist. I'd like to get the mirror off for my current car. The fellow who took the door off left the power window up, and just cut the wires coming out of the door. So no connectors on the wires.
Any way to roll the power window down without power? I can't get at the mirror bolts with the window up.
Alternately, can I remove the window without breaking the glass?
Old 01-22-2016 | 11:14 PM
roadthrills's Avatar
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
Re: how to get power window down?
Just strip the wires back that go to the motor and touch them to your car battery, reverse them for the opposite direction. A long piece of speaker wire will work.
Old 01-23-2016 | 01:18 AM
Night rider327's Avatar
Car: 1988 Camaro
+1 what roadthrills said.
Strip the ends of the cut power wires and touch them to a car battery + and -. I have test leads made up for things like this. A gator clamp on one end and a battery charger type clamp on other end.
clip the gator clamp onto stripped wire, and battery charger type clip onto a battery.
12 volt motors like these are reversible, so you can't really hook them up backwards and burn anything up. One way will cause motor to turn clockwise, other way will run it counterclockwise.
Old 01-23-2016 | 07:43 PM
L-Train8's Avatar
That worked great. It was really easy. Got the window down and got my mirror off. Thanks guys.
89irocz355
10-08-2023 01:59 PM
89irocz355
101
09-19-2016 05:05 AM
89irocz355
Exterior Parts for Sale
25
04-07-2016 04:34 AM
89irocz355
12-26-2015 08:44 AM
mans1
12-20-2015 12:27 PM
