Help me ID this stuff!
Car: 87 Firebird
Engine: 2.8 Liter
Everything on the right came off of an 88 GTA. <br/>Far left two white ones and all purple came off of a 91 transam. Help me figure out if I've got a whole set of ground effects or not. I've got the back bumper from the 91 but not the gfx for the rear.
Help identify what these are please!
The 91 the gfx came off of.
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Re: Help me ID this stuff!
The white pieces between the purple and it looks like silver pieces in the third pic are the door trim pieces from a 90 or older camaro. They bolt directly to the bottom outside edge of the door. The two black pieces on the left in the second pic are the scrape guard that goes under the front nose of the car, you have two of the same piece, the piece beside those two looks like the air damn pieces from a camaro.
The silver pieces, to me, look like the front fender ground effects for a 91/92 Firebird.
It looks like you have a full set of 91/92 gfx there (minus bumper covers) using the long and large white pieces, the long purple pieces, the dark silver/gray pieces, and the squarish purple pieces.
You seem to have a spare 92/92 front fender piece (the silver ones) and the skinny long white pieces are either Camaro or 85-90 Firebird door pieces.
You are missing the door ground effect braces it appears.
You mentioned that you have the bumper off of a 91, but not the ground effect. The bumper and ground effect are one piece, so if you have a bumper off of a non ground effect car you won't be able to add the ground effect.
LT1Formula
10-08-2015 08:34 PM
