87 trans am "extensions"
Car: 87 trans am
I'm restoring my 87 firebird, when I took it apprt for paint I found my fender, quarter, and rocker extension retainers a just about shot, Ive been t trying to find new retainers, but th He y are obsolete through gm and no one sells just a retainer, hs anyone gone through this.does anyone have any leads to where I can get just the retainer
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: 87 trans am "extensions"
You can try this place,I've had some good luck with them in the past.It would be a nice idea to get a Parts And Illustration Catalog to get the P/Ns from it.
http://www.clipsandfasteners.com/default.asp
Car: 1992 Formula 350
Engine: 5.7 L98
those items you're referring to have been discontinued. Every now and then someone will be selling an NOS one on ebay but in all honestly your best bet is a junkyard.
Car: 87 trans am
Right on so there is absolutely nothing aftermarket? Any other suggestions
Engine: 5.0 EFI
If there what I think they are,I had a couple of bad ones, (studs missing)had them reweld the studs back on.
Car: 89 RS
Engine: 305 TBI
Easy to make them. I picked up a 3' length of 1" aluminum at the hardare store and cut it to the length needed. Then held it against the fender and checked the shape. I had to clamp it in my vice and give it a bit of a twist to sit nicely. Then marked the holes, drilled and tapped for M6 bolts and put some bolts through it with loctite. then it works just like the stock one, slip it on inside the fender and use nuts and washers behind the GFX.
Mine was on a Camaro, but it can't be that much different.
Engine: 5.0 EFI
http://www.hawksthirdgenparts.com/fi...ver-side-only/
Here you go!!Hawks has them,one side,but it's a start.
Built my own, can't remember the ga of steel I used, but I simply drilled holes in it in the proper location, put a bolt through each hole, tacked them in there and ground the heads off. Worked just great.
1992 Trans Am
05-10-2023 07:19 PM
