Big dent on lower quarter panel
Old 04-05-2015 | 04:03 PM
slayer6969's Avatar
I discovered that someone dented my project car and I was wondering what the best way to go about fixing the dent behind the tire also was wondering the best way to fix the dent on the flare...I would like to use very little bondo or better yet none any input will be appreciated
Old 04-05-2015 | 06:45 PM
PurelyPMD's Avatar
Car: 1987 IROC Original Owner
Engine: LB9
Transmission: M39 MM5
Axle/Gears: G80 G92 J65
Re: Big dent on lower quarter panel
I had this dent on the passenger side rear quarter (behind the spare tire) on a car recently. My paintless dent guy got it out in about 25 minutes. If you check out the last pic you can't tell it was ever there!
Old 04-05-2015 | 08:04 PM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Looks like a base model? Could hit junk yards and get the ground effects from a 91 - 92 RS, that should cover that up, and look good!
Old 04-06-2015 | 09:57 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Some time and patience with a body hammer and that'll come right out. Plus, if you put ground effects on it it will be covered.
Old 04-06-2015 | 04:34 PM
slayer6969's Avatar
The salvage lot I go to has like 4 or 5 third gens (kinda sad that people just scrap them) but not sure of they have any 91 or 92s thanks for the help...but for the fender flare should I just cut and weld a new one or try to hammer it out as well
Old 04-07-2015 | 07:48 AM
Car: 1983 Z28
I'd always use cutting and welding as a last resort.
1992 Trans Am
05-10-2023 08:19 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 11:36 PM
Tony Ferrarri
08-11-2015 08:59 PM
blacksunshine'91
Interior Parts Wanted
08-10-2015 01:04 AM
Exxon Limited
08-09-2015 09:13 PM
Quick Reply: Big dent on lower quarter panel
