Door rods
Old 04-04-2015 | 08:08 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Door rods
Need a lil bit of help.
Can anyone point me in the right direction?
Driver side outer handle has gotten very sloppy. I believe the push nuts / speed nuts were the wrong size to begin with, so I will be tackling that next week.
Also, the key lock has quit working.
I need pics or direction to schematics of the correct door rod orientations for Driver side. Locks worked 1 time, that's all! Key is hard to turn, so I don't want to force it.This is another issue that I have let slide for 8 yrs!
Any / All help MUCH appreciated!!
Doors are MANUAL LOCKS, not electric if that makes a difference?
Old 04-04-2015 | 08:45 PM
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Re: Door rods
This is for a Firebird,i'm sure they are the same.
Old 04-04-2015 | 08:57 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Door rods
OPPS! Here's the rest
Old 04-04-2015 | 09:44 PM
Car: '87 Camaro
Re: Door rods
Thanks VERY MUCH
mantaguy!!
Old 04-04-2015 | 09:48 PM
mantaguy's Avatar
Engine: 5.0 EFI
Re: Door rods
Originally Posted by t-top havoc
Thanks VERY MUCH
mantaguy!!
I hope that helps you out
Old 04-05-2015 | 08:07 PM
Wife'sCar's Avatar
Car: 91 Camaro RS T-Top
Engine: 5.0 Tbi
Re: Door rods
My handle has gotten real loose as well, but looking at it close it's from the pivot point wallowing out on the handle pivot, not much to do besides replace the assembly for mine. Hope that's not the case for you.
Old 04-05-2015 | 08:50 PM
Car: '87 Camaro
Re: Door rods
Me too. These are the originals, and when it went back together after paint, I did
not notice anything....but I needed it done by a certain date so not too much attention paid.
Honestly hoping a rod popped out and nothing more than new nuts for the handle.
Friend recommends new keys // locks when I take it apart.
Old 04-05-2015 | 09:30 PM
Wife'sCar's Avatar
Engine: 5.0 Tbi
Re: Door rods
I guess you could. But that would require taking the other door apart as well as the hatch key lock.
Old 04-05-2015 | 10:54 PM
Car: '87 Camaro
Re: Door rods
Very true!
Sometimes a day off goes too fast! It will be about 8 days before I get a day off, this ranks in #3 priority of 5 to do items, so chances are good I will have a half day to get it apart, look things over good, hopefully fixed & back together!
Hotrodboba400
12-10-2019 08:07 PM
1Aauto
Sponsored Vendors
01-15-2016 07:26 AM
1Aauto
Sponsored Vendors
09-10-2015 03:02 PM
Hotrodboba400
09-02-2015 08:28 PM
1Aauto
Sponsored Vendors
09-02-2015 02:35 PM
Quick Reply: Door rods
