Trans Am GTA bumper colors.
Car: Camaro RS Convertible
Engine: 305 TBI
I am looking at a GTA for sale, but in the pictures, the paint color looks slightly off. I'm messaged the owner and they said it was the way the Sun was hitting the car, and then pointed at the auction for the gray GTA for sale on Hawk's Third Gen. Is it typical for the color to look off in pictures on these bumpers, or is he trying to pull a fast one? The AutoCheck is clean, but that can be avoided by fixing the car at home.
Engine: 305 TBI
Re: Trans Am GTA bumper colors.
The paint is metallic gray, I have read that it is common for metallic paint to appear mismatched on cars when the plastic is painted at the same time as the body. Colder sheet metal with warmer plastic will cause the plastic to appear lighter in color, and vice versa if the sheet metal is warmer than the plastic. The spoiler has a similar appearance, but has the typical 88 spoiler paint issues. Any body repair/body painters care to weigh in?
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
The bottom line is that if you are relying on photos and the seller to disclose everything on 25plus year old car, you are at their mercy. There are many things that need to be checked out in person before you hand over any money. Mismatched paint and signs of accident damage are the most obvious things on a newer car, but on a car this old they could definitely be the least of your problems. There is no substitute for personal inspection on a classic car, just setting yourself up as a sucker otherwise.
Any analysis of the color in photos is useless, could be light reflection, camera quality, display color, etc.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
My red '88 GTA has that same appearance in certain light conditions...the front and rear bumpers look to be a different color red due to age.
Once had a fellow at a car show tell me I needed to take it back to whoever painted it. Told him that would be hard since the plant was gone...
Engine: 5.0 EFI
Most likely they were replaced of repainted at one time off the car,because they are the same color as the rest of the car
Long as I've had my 92 GTA (15yrs) the front bumper always seemed darker, in pics and in person. The rear bumper was always a perfect match.
I just had the entire car taken apart and repainted. Rear bumper is a perfect match but the nose still looks darker! My factory color is a mica rather than a metallic (even tho GM calls it a metallic). I really can't explain it. Perhaps it has to do with the curves the nose has vs the rear, it's weird.
If you look close at even allot of brand new cars, it's pretty common.
1992 Trans Am
05-10-2023 07:19 PM
colton_carlson
03-08-2019 12:21 PM
The_Phoenix
02-04-2016 07:10 AM
