Adjusting doors after weatherstrip replaced
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
I was wondering if anyone has a write up or can explain to me on how to adjust the doors after the weatherstripping was replaced. Prior to that the doors closed perfectly. Thanks
Engine: 4++,350 & 305 CIs
Re: Adjusting doors after weatherstrip replaced
Install "cheap" weather stripping?
Car: 88GTA
Engine: 5.7TPI
If your doors were fine, not sagging, good order BEFORE, then after you install new, you shouldn't have to adjust the doors.
I beg to differ with it being an issue of cheap seals. I have soffseal weatherstripping and it is tight even a year later. I adjusted the doors where you could latch them shut with one finger before weatherstripping. The crush zones are just molded too thick. You'll find quite a few accounts of this on here with metro and soffseal, which seem to be the favorite choices.
Transmission: Pro-built 700R4
I had that issue for a while after I changed my weatherstripping. Give it some time. The new seals will eventually conform to the door channel. No need to adjust your doors. Remember, you were used to closing your doors with ~25-30 year old seals. They pretty much lost their elasticity.
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
Patience is a Virtue
They are metro seals that I installed. Do you think I should find oe seals
Engine: 5.0 EFI
Why do that,just keep the doors closed for a while,they'll settle down.
Car: 1992 Formula 350
Engine: 5.7 L98
Thanks for the input guys. When i get the car back next week ill check it an see.
Not every model of our cars has elongated holes for the door strikers, I'm afraid.
My 91 Firebird, for example, did not have them.
I had installed Metro door seals and couldn't shut the doors properly.
Had to SLAM them shut. But, after a couple of weeks, the doors could be closed with normal effort again.
Engine: 5.0 EFI
I f your car will be back in a week or two and the doors are kept closed,most likely your seals will take shape
Carefully warm the new seals with a heat gun then close the door and leave it for a while. You may notice a slight improvement, if so you can repeat several times until the seal crush areas are re-formed.
1992 Trans Am
05-10-2023 07:19 PM
92firebirdchris
Exterior Parts for Sale
08-14-2015 11:56 AM
