85 trans am lift supports help
Car: 85 Trans Am
Engine: 5.7TPI
Hi guys. Having some trouble finding correct lift supports for my 85 Trans am. Has wrap around spoiler and no rear wiper I purchased the rynopac 4900 and they don't match up to what I have and don't know where to get the correct ones or maybe a different mounting bracket? The replacement part#4900 has a through hole where it mounts to the body. Where the ones I have on the car has a threaded hole on the end where a bolt goes through to mount it.
Car: 1986 iroc-z
Engine: lt1 intake 406
Axle/Gears: stock 89 gta 10 bolt 3.42 non posi
Re: 85 trans am lift supports help
That looks to me like someone made the adaptor, all the cars I have seen have the through on the end
Car: 85 Trans Am
Engine: 5.7TPI
Weird. But that would make sense. So how would I go about fixing this? Is there a replacement adapter that I can get?
Car: 85 Trans Am
Engine: 5.7TPI
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
http://www.autozone.com/collision-bo..._670920_19977/
These are for the hatch with the wraparound spoiler
Engine: 5.0 EFI
The ones bolted up,are they the ones you changing?
Car: 85 Trans Am
Engine: 5.7TPI
Yes the one bolted up are the ones in changing. If that bracket is not stock I would prefer to remove it.
Engine: 5.0 EFI
Not stock,looks stupid.Also after you remove that,their is a cap that covers the bolt.
These are the caps.
http://www.hawksthirdgenparts.com/ca...ch-strut-trim/
These are the caps.
Car: 85 Trans Am
Engine: 5.7TPI
Yeah they are pretty hidious. A small detail that I overlooked but wondered about. I have the caps but didn't know if I was missing something cause they obviously didn't fit lol. Thanks so much for all the help! Those ugly things are out of there
Car: 88GTA
Engine: 5.7TPI
Whoever made those brackets should at least painted them up with something. They would've looked a little less hideous.
1992 Trans Am
05-10-2023 07:19 PM
